Do I still need my Boost Solenoid?
I have a manual boost controller and my boost solenoid is all capped off. Can I remove it all together without causing any problems?
Also, For the other two sensors that I'm still using, do they need to be oriented the way they were from the factory? I just moved them behind the brake proportioning valve or whatever that thing is and they're crooked now. One is sideways and the other is upside down.
wtdash
Re: Do I still need my Boost Solenoid?
Post by wtdash »
You'll get a CEL w/out it plugged in - stock and EJ20G ECU. If you get a 'dropping resistor' (DR) from an AT-equipped car (turbo and NA) it will prevent the CEL- it has the same plug/connector. They are mounted on the backside of that bracket that holds the turbo sensors.
EDIT: Check the plug on the BCS. The DR were round on the '90-91 Automatics; square on the '92+. Per Josh's link below.
I don't know whether the other sensors need to be kept upright.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
So far no problems with the way they're mounted. What is a dropping resister? I'll go look for one in the junkyard. But I didn't think NA cars had that bracket?
wtdash
Post by wtdash »
Kimo,
Sir Josh created THIS.
And a pic from an NA for reference. On a different bracket:
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
I see, cool. Not as cool as removing it completely and not replacing it but that might be smaller and easier to tuck away where the other sensors got moved to.
What is this green labeled box bolted to the frame rail?
wtdash
Post by wtdash »
Huh...IHNFI. :-)
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
It says "do not drop" on it I think.
It may be an airbag sensor or possibly a g sensor for the ABS system. I'm going to guess g sensor, usually the airbag sensors are closer to the front of the car.
wtdash
Post by wtdash »
^If his is a '91 - no airbag, so ABS makes more sense.
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Yes, no airbags for me. Except in my WRX seats...
Picked up the na automatic resister for $3 at the junkyard.
sweet
SiCkSTi04
Post by SiCkSTi04 »
kimokalihi wrote:It says "do not drop" on it I think.
Got a part number on that thing? I'm wanting to know as well
It's an ABS sensor. Probably to tell the computer which direction the car is going?
Part number 26740AA040.
SB117405 SENSOR AY [New Part# 26740AA040]
List Price:$222.37 (dealership)
Your Price:$160.10 (1stsubaruparts.com)
2nd google hit came up with this: http://www.surrealmirage.com/vrg3/partnumbers/
ABS G Sensor
i_c_the_light
Post by i_c_the_light »
I have been trying to figure out what that sensor is for the past 3 months!
1990 Legacy GT wagon. 100% JDM, 100% factory.
hmm, maybe it should go away if you don't have abs :P
It will when I get rid of abs. For now the ss sits collecting rust on its rotors looking real sad.
that is sad, I wanna get rid of my ABS too...
What do you need to do to get your car running again, just have that piece welded back on?
Don't know. Haven't even looked at it. I just removed the battery to use in my metro and went from getting 23 mpg to 42 and I haven't had time to pull the tranny to find out what broke. My guess is new clutch fork and clutch.
no bueno
