Help with my parts
Posted: Thu May 03, 2012 5:04 am
by General Led
Im looking for parts for my 93' Turbo Subaru Legacy and I was curious if the 96 CV boot will fit my 93 Turbo Legacy? Also will (96) power steering and a (96) passanger axle fit without a problem?
Re: Help with my parts
Posted: Thu May 03, 2012 10:00 pm
Welcome to the BBS.
The boot should work, but you'll have to look at your cv axle to know for sure.
Does the 96 have ABS? The parts book shows different part #'s, but that doesn't always mean they wouldn't work. Are you talking about the front or rear passenger axles?
Are you talking about the power steering rack or pump?
Posted: Thu May 03, 2012 11:58 pm
by General Led
Both pump and rack I need new of. haha
and its the front of that passanger axle. Thanks man it really helps to have someone aid me.
Posted: Fri May 04, 2012 4:21 pm
I'm pretty sure the tie rod end design is different between the first gen legacy and the second gen. If that is the case, you could probably just switch the tie rod ends to the ones from your steering rack.
Posted: Fri May 04, 2012 10:19 pm
by General Led
No it does not have ABS is that a good thing or bad?
Posted: Sat May 05, 2012 3:03 am
by Flatfourced
as far as the rack goes they are the same. I am sure on the years mentioned. I am currently harvesting parts from a 91 turbo that i can use on my 97 legacy. And the rack is common across alot of subarus.
Posted: Sun May 06, 2012 9:36 pm
Well I was thinking there may be a difference in axles between the non-abs & abs, but now I'm not so sure. Do you have any pictures of the 96 axles?
