ABS screw under the center console how to remove it
Posted: Thu May 10, 2012 9:58 pm
by yazmo
hello anyone know what kind of screw driver i need to use to remove the abs unit
its like a kind of star with a pin right in the middle i dunno how its call so i may find the tools i need to remove it.
thx in advance.
also i need to change the cover of the speed shifter automatic, bcuz the plastic is broke
its seem that i have to cut the wire on the shifter under the center trim cover, to remove it,
is there any other way to remove the center console without cutting the wire to set the transmission on manual mode?
Re: ABS screw under the center console how to remove it
Posted: Thu May 10, 2012 10:09 pm
by evolutionmovement
That sounds like a security torx or TR torx (tamper resistant) driver you'll need. You should be able to find a folding set for around $12, but you'll probably have to order it as you're not likely to find it on a shelf at the hardware store. The good thing is that they work fine as a regular Torx drivers, too.
Posted: Fri May 11, 2012 1:37 am
by yazmo
thx a lot
Posted: Sat May 12, 2012 4:06 am
by Bheinen74
but, the unit under the center console is not the abs unit.
It is the SRS unit.
abs=antilock brake system
srs=supplemental restraint system ie airbag system brain/
The srs unit is in the console, and yes it requires tamper proof torx i believe t20 is the one....
a helpful hint is do not buy the cheapy torx set at autozone, advance, etc. They will bend and break the end due to the fact those screws have glue on them holding them TIGHT.
you need a quality set.
I have done this before.
Posted: Sat May 12, 2012 11:40 am
by yazmo
Yea your right its a srs unit thx for the info ill try to get one good set thx again
Posted: Mon May 14, 2012 12:01 am
Be careful removing/disconnecting the wires of the SRS control unit. Make sure to disconnect the battery so there's no chance of the airbag accidently deploying.
Posted: Mon May 14, 2012 3:43 am
by yazmo
sure but in my case the engine bay is completely empty so don't worry about it : )
Posted: Sat May 26, 2012 1:51 am
by oldscoobyturbo
you can get tamper proof torx bits from princess auto
Posted: Sat May 26, 2012 2:31 am
by Grayguy
I've always used a vise grips, not pretty but it works
Posted: Tue May 29, 2012 6:19 pm
by S Webster
Harbor Freight sells a set of about 20 different security bits for around $10. Don't know if you have access to their catalog or store. Luck, Steve.
