Cruise control on an ej20g?
Posted: Mon Jun 04, 2012 9:46 am
Not sure if this is the right place.
I was previously using an ej25D intake manifold (a JDM one at that - no EGR!) and both my throttle and cruise cables fit perfectly.
I switched to a complete ej20G intake manifold which solved most of my problems related to jerry-rigging.
Anyways, the throttle cable fits perfectly, but the cruise control cable has about half an inch of slack now. Meaning, I can't tighten the nuts on both sides of the bracket.
It does in fact work, but there is a second or two of delay before it engages cruise after hitting the stalk, whereas before it engaged pretty much immediately.
The bracket from the ej25d doesn't fit, so is there some other solution to getting this to work properly?
The intake manifold is from a JdM Legacy RS I believe. Build date is 3/90.
