Stock engine photos.
Posted: Thu Jun 14, 2012 9:42 am
I was wondering if any one on here had a link to several stock engine photos. Amongst my swap, I was wondering where the lines hooked up for the plastic pipe that is made out of the same material as the f pipe. I know one end goes into the black intake 90 that goes down the the turbo inlet. I was wondering where the other sections hooked up, or if when I was doing my swap Im just not realizing that it is something that has to be blocked off like the big hose that comes off of that 90 into the stock bpv. The big hose that does from the bpv into the black 90. I hope this makes sence, I can elaborate if need be.
