FS: JDM Manual Seatbelts & Trim - Grey fuzzy/suede
Posted: Thu Oct 04, 2012 6:16 pm
This set of manual seatbelts was pulled from a 1990 JDM RHD Wagon. They are grey in color and have the JDM soft and fuzzy finish instead of hard plastic. I am not sure the appropriate term for the material, it is not wrapped but almost coated
I am tempted to use these belts myself, but, the fact that these came from a wagon means the C pillar back is different than my sedan.
So, I am putting them up here in case someone with a wagon is motivated to have manual belts and get to use JDM stuff to replace their entire trim including C and D pillars and the rear ceiling.
Shipping all of it will be costly, so I am looking for $300 shipped.
Regular kit w/ manual belts, A & B pillar trim
The lower portion of B pillar is the same plastic finish as USDM, (JDM fuzz on left)
Tried to use glare to emphasize difference.
At this joint on the A trim, you can see the plastic underneath and the seam of the felt. I think the 'felt' might be sprayed on?
Wagon owner alert! This set includes the rear pillars and piece that joins the sides across the rear ceiling.
