Mud flaps for a 1990
Posted: Mon Oct 08, 2012 3:44 pm
by FundamentalyConfused
Does anyone know if there's a molded mud flap for the 1990 models?
Would the 1995 stock molded flap be compatible enough to make it work?
Re: Mud flaps for a 1990
Posted: Tue Oct 09, 2012 9:47 pm
by evolutionmovement
Yes and I don't know.
Posted: Tue Oct 09, 2012 9:59 pm
Thanks for the reply evo.
Do you have a stock number or a company I can talk to about the 1990 model ones?
Posted: Tue Oct 09, 2012 10:55 pm
I bought mine at the dealer. I believe all the gen 1 cars were the same except one might have said, 'LEGACY' and the other, 'SUBARU'. I don't know, it was probably back in 1999 or so.
Posted: Wed Oct 10, 2012 2:16 am
Man this is a tough nut for me to crack. I've looked in the 2 different legacy parts catalogs I have and there's not a single thing in there about a mud flap or a stone guard, the splash guard is in the catalog but that's the plastic in the wheel well.
I put in an email to one of the 30+miles away dealers. I'm not too hopeful on that but I figured it was worth a try.
Not a thing on the web that I can find yet about the stock ones but I'll keep looking.
Posted: Fri Oct 12, 2012 6:32 pm
The reaseon you can't find anything on mud flaps is because they are something that is typically installed at the dealer and is a dealer option. Those components are in separate catalogs. The chances of finding the mudflaps is probably going to be pretty difficult.
Posted: Fri Oct 12, 2012 10:47 pm
FWIW, mine were in a dealer catalog. There were pictures he showed me of them to pick them out. IIRC, there were 3 styles: "Subaru", "Legacy", and blank (perhaps also a simpler design that didn't hug the fenders). They were, like, $8. Since these cars are so old, you're best bet might be an old dealer who could still have some sitting on a shelf under a layer of dust.
Posted: Sat Oct 13, 2012 12:04 am
by sqc151
i might have mudflaps. ill check later and pm you pics if i have them.
Posted: Sat Oct 13, 2012 12:38 am
So the dealer said they found the flaps but only the rears are order able cuz the fronts are obsolete.
Posted: Sat Oct 13, 2012 2:00 am
by oldscoobyturbo
get part numbers and post them up I'll see if I can dig up a set
Posted: Sun Oct 14, 2012 3:14 am
by sqc151
i pulled these outta the stash, there not bad, just need a cleaning.
Posted: Tue Jan 22, 2013 6:38 pm
by fngearhead
Just a little something to keep in mind, the rears are different between wagon and sedan. 4D or SW are the markings to look for.
