CP pistons and ej22e block
Posted: Sun Nov 18, 2012 4:08 pm
by flyguyeddy
ok i bought these pistons from a nasioc forum member for my ej22 build. i located an eg33 in an svx so i decided to go with it instead.
the pistons are made to be used with a 48cc head and a wrx head gasket, which will net you 8.0:1 compression. they have 3000 miles on them. i had the skirts coated at swaintech with their dry lube coating. i have the rings and pins that came with them but i dont know if they are any good. they will be included in the sale anyway. a new ring pack is less than 200 from cp. (i say if the ring gaps are ok in the engine i see no reason to not use them)
anyway the block is an ej22 engine from a 92 legacy. i had it bored to fit the pistons at Mullvain Motorsports here locally. i also cleaned the engine block and bead blasted the top of the case (corrosion removal, basically)
the last pic is of the rings bagged and organized.
i dont have any pictures of the block yet as its bagged up so no moisture gets in. if you would like some just text me and ill take some.
it would be easier to get ahold of me at my cell number. 309241257nine. i have this listed at other websites too.
asking 400 for it all plus shipping. willing to negotiate trades.
Re: CP pistons and ej22e block
Posted: Sun Nov 18, 2012 10:58 pm
by mike-tracy
Have any rods for this build?
Posted: Mon Nov 19, 2012 12:06 am
by flyguyeddy
I have 6 still rods that I know for sure 3 are good. I haven't measured the other three, but I don't see why they wouldn't be fine.
Posted: Mon Nov 19, 2012 5:21 am
by mike-tracy
What rods are they?
Posted: Mon Nov 19, 2012 1:28 pm
by flyguyeddy
Damn auto correct. STI EJ257 factory rods
Posted: Sat Nov 24, 2012 10:57 pm
by mike-tracy
What would you want for 4 good sti rods, shipped in a flatrate box?
Posted: Sun Nov 25, 2012 5:26 am
by eggc
what do you want for the rods+pistons+block?
how are the bores?
Posted: Mon Nov 26, 2012 3:16 pm
by flyguyeddy
Rods+pistons+block 300+shipping. Don't really want to separate it out
Posted: Mon Nov 26, 2012 3:25 pm
by flyguyeddy
Also I can be contacted via text @ 309241257nine
