WTB Ej22t crank : dfw tx
93gc8awd
Post by 93gc8awd »
Sent motor to machine shop. They said the crank is beyond salvaging. Need another with paperwork from machine shop saying its ok. If its alright, I'll buy it and pay for that shop to balance it if needed.
rallyak
Re: WTB Ej22t crank : dfw tx
Post by rallyak »
You could find a used n/a crank, they are the same as 22t. I personally will use a good used crank than undersized recon. one. I've worked in a machine shop and found many cranks that was turned didn't meet specs.
Charles
93gc8awd
Post by 93gc8awd »
rallyak wrote:You could find a used n/a crank, they are the same as 22t. I personally will use a good used crank than undersized recon. one. I've worked in a machine shop and found many cranks that was turned didn't meet specs.
So the n/a crank is forged also? I have plenty of those!
COTruckin
Post by COTruckin »
I have 3 or 4 ej22t cranks, let me know if you are still looking for one.
rallyak
Post by rallyak »
I'm pretty sure they are there forged as well but others could chime in and confirm.
Charles
