Fuel Pump Assembly differences - turbo and n/a
Posted: Mon Dec 17, 2012 7:26 pm
by macipusy
What I have gathered from the FSM is that the fuel pump assembly is the same between n/a and turbo models with the pump being the only difference. Can anyone verify this for sure? If I go to the salvage yard and pull a 92-94 n/a fuel pump assembly and swap it into a 93 turbo wagon with a walbro fuel pump, will it work?
Re: Fuel Pump Assembly differences - turbo and n/a
Posted: Mon Dec 17, 2012 7:40 pm
You are correct. The fuel pump assemblies are the same.
