WTB ecu connector pins
Posted: Mon Jan 14, 2013 9:46 pm
by 93Leg-c
Hey there! I'm looking to get 2, preferably 4, ecu connector pins. Does anyone have any available? or perhaps a connector they can part with? It can be from either a turbo or NA ecu, pre-facelift or facelift models. Thanks!
EDIT: For some clarification, please see my second post below, post #3 on this thread. Thanks!
Re: WTB ecu connector pins
Posted: Tue Jan 15, 2013 1:56 am
by oldscoobyturbo
I'll check my stock I should have a plug with pins in it
Posted: Tue Jan 15, 2013 3:25 am
by 93Leg-c
Thank you. I would appreciate it if you would check for me.
I was not clear in the first post but after emailing Josh and looking at the pinout diagram on Josh's site, I need to clarify what I'm looking for: On the Legacy ecu, there are four connectors that plug into it and within those connectors are the pins that hold the wires. There are two size pins in those connectors. I'm looking for the smaller pins. I need to make a new knock sensor wire because the one on the ss is brittle and broke in two. Rather than patch the wire, I"m going to make a whole new one. At the ecu end, the knock sensor wire goes to the B56.5 pin and the knock sensor ground (shield) wire goes to the B56.4 pin.
I just found out last night that the car needs to be running next week. So, this coming Sunday, I have to fly to AZ and within 1-1/2 days I need to get my '93 ss in dependable running condition. I have to fix the broken knock sensor wire, drain 15 gallons of bad fuel from the gas tank, replace things like fuel filter and spark plugs, change the fluids, check the brakes, remove some window film, replace the cracking top hats, and do others things that I don't recall right now. But anyway, time is going to be precious once I get there so I'm hoping to get the wiring done ahead of time so when I get there all I'll have to do is route it and connect the ends and go on to fixing something else.
So, if anyone can part with a couple of their pins or even one of their connectors, I'd appreciate knowing about it! Many thanks!
Posted: Tue Jan 15, 2013 5:10 am
by oldscoobyturbo
take a look at this pic and pm me its all good
Posted: Tue Jan 22, 2013 5:07 am
by 93Leg-c
I picked up an ecu connector so I'm set. Thanks for the posts and PMs!
Posted: Sun Feb 10, 2013 6:18 am
by 93Leg-c
I didn't mention, but if anyone needs pins, I now have extras that I'll be glad to send to you if you need them.
