N/A ToB retainer clips
Posted: Wed Jan 16, 2013 10:59 pm
by Someperson
Anyone have a part # on these little buggers? Mine sprung when I took off my trans... Also compatibility between FWD and awd 5mt clutches? Same or? They look close but not too sure on actual fitment. ToBs look identical
Re: N/A ToB retainer clips
Posted: Fri Jan 18, 2013 6:56 pm
Searching is your friend :)
http://bbs.legacycentral.org/viewtopic.php?f=12&t=631
Seventh post down.
Regarding the clutch, the parts book shows them as different part #'s, however the pressure plate is the same, so I would just imagine that the springs and/or clutch material may be slightly different. With that being said, they should be interchangable though since the flywheel & pressure plate are the same.
Posted: Fri Jan 18, 2013 11:55 pm
by Someperson
tried searching, srry i usually use asking as a last resort. or if i'm in mid project
Posted: Mon Jan 21, 2013 1:05 am
No worries!
There's a lot of posts/info in the stuff you need to know forum that a lot of people don't run across regularly.
