Looking for the basic parts to turbo an NA 2.2;
What I need:
Heads - NA or Turbo (must have water/coolant connections on passenger side)
Injectors w/rails OR
RRFPR/fuel pressure regulator
Turbo Coolant Tank - WRX metal preferred
I have or know where to get:
3 turbo sensors on bracket + dropping resistor
VF11 turbo - with oil and water lines
Turbo compressor-side 90° intake hose (the one you can't buy in the US!)
Bracket for turbo/up pipe
Downpipe
EM
turbo>>throttle body pipe w/BPV
heads
exh. manifold w/up pipe
water pump
water pipes - for turbo
Turbo IAC
water cross-over pipe (maybe) - the NA one has it's coolant/temp sensor right where the turbo 90° comes out.
STi exhaust-mid/axle-back
Notch crossmember
INFO
NA turbo of Phase 2 2.5:
reference on injectors
Edit: Per JC's test the EJ22's aren't that low - LINK
At 5 psi, these were the settings required at 5000 and 6000 rpm to keep EGT's under control and retain good engine response characteristics:
Code:
Type Color Flow Boost Fuel Press EGT S-AFC correction
EJ22 Grey 220 cc/min 5 psi 80 psi 1550°F +25% (Note A)
EJ25 Red 280 cc/min 5 psi 75 psi 1425°F +15%
EJ22T Pink 360 cc/min 5 psi 50 psi 1250°F -15%
EJ22T Pink 360 cc/min 7 psi 90 psi 1500°F -25%
SR20DET Purple 370 cc/min 7 psi 52 psi 1450°F -8% (Note B)
Notes:
A. MAF output voltage maxed out at 5.0V, so any further correction was useless.
B. EJ22T hybrid with 9:1 CR.
