Up for sale is a Jdm 96 ej20h(twin turbo) motor 67k on the motor. its missing cam timing gears (same as wrx) other wise it's a complete motor with header and turbos -$1400 Obo
93 eg33 h6 motor 110k with a full body/engine merge swap harness out of a 92 legacy. 92 Svx modded ecu(ecutune stage 2) I also have the Na crossmember and all the hoses for the swap. -$1300 Obo
Ill get pics up when I get home. Thanks for looking
Fs: Jdm turbo motor and full h6 eg33 swap
•94SS full cage 2.2 hybrid build with 04 2.5i heads,JIC coilovers,jdm 4pots,vlsd,jdm TD05 16g ,top mount IC,950 injectors,running ms3x em
•91ss ej22t 110k,rebuilt heads,new seals,delta220 cams,td04,wrx top mount,wrx flywheel,wrx trans
•92L drift project h6 rwd
