91 SS Engine died tonight
Posted: Sat Mar 09, 2013 8:00 am
by fireman2101
Had a not so great drive home that ended in tick tick tick tick boom
Re: 91 SS Engine died tonight
Posted: Sun Mar 10, 2013 12:37 am
by rallyak
Oh noooooo, that sucks man.
Posted: Sun Mar 10, 2013 12:55 am
by robertpaige
How many miles on the engine?
Posted: Sun Mar 10, 2013 1:07 am
by fireman2101
207k
Posted: Sun Mar 10, 2013 11:41 am
by robertpaige
I'm at 191k. Now I'm worried.
Posted: Sun Mar 10, 2013 1:19 pm
by James614
Any mods that could have possible contributed to that? Seems like a very odd way for an old engine to go.
Posted: Sun Mar 10, 2013 3:18 pm
by fireman2101
I do have a robtune and run 18psi boost which could have contributed. I by no means baby the car either and I am not the most confident that regular service was the highest priority on the previous owners mind.
Posted: Sun Mar 10, 2013 3:40 pm
by James614
Well, I'm glad I'm only gonna run 15 psi on my rob tune :)
Posted: Sun Mar 10, 2013 4:23 pm
by mike-tracy
I don't think the robtune had as much to do with it as the condition of the engine. My first SS came with a hole in the block just like that, and it was 4eat and bone stock.
Posted: Sun Mar 10, 2013 4:29 pm
by fireman2101
I don't think the robtune had anything to do with it either. It probably made it last a little longer with the tune vs me just running higher boost on the stock computer. I think lack of oil changes over the year was the biggest thing but I don't have service records and it was just the overall feeling I got from the gentleman I bought the car from.
Posted: Sun Mar 10, 2013 4:36 pm
by James614
I don't seriously think the robtune had much to do with it. But I don't see how poor oil service could cause it to blow a hole in the block, either...
Posted: Mon Mar 11, 2013 6:31 am
by randomiam
The only way you blow a whole in the block like that is driving it way too long with a rod knock, I know because I had a motor that this happened to (not mine, thank god).. Youtube the shit out of various sounds because that would have sounded quite a bit different than something like lifter tick
and it seems much more likely that anything tune related would have demolished the pistons rather than a spun bearing driven way too long, like this.
seems like an oil pressure gauge might give you a good warning that something like this will happen soon
Posted: Mon Mar 11, 2013 7:41 am
by James614
I've often wondered why cars don't have oil pressure gauges from the factory. The warning light usually means youre already causing catastrophic damage. A little warning between then and normal would be nice without turning to the aftermarket.
Posted: Mon Mar 11, 2013 9:57 pm
by fireman2101
My thought was if the previous owner didnt keep up on the oil changes it may have gotten too low a few times and possible cause some excess bearing wear which over 200k could make a difference.
I have had rod knock in other cars and it wasn't as loud/pronounced as I have heard in the past. If that makes any sense. It wasn't lifter noise. It was louder than that. It was only making noise for 30 seconds before it blew. The motor has been great up untill this point.
I don't think they put oil pressure gauges in cars because they vary too much. Can you imagine all the not so car educated people coming out on a cold/hot day and seeing their oil pressure not where it normally is. All the calls that would come into service centers over it. I think most people prolly dont even watch their temp gauge at all so whats the point of putting something in you have to be more mindfull of.
