Few questions about manual transmissions
Posted: Sat Mar 30, 2013 1:37 am
I'm having a little debate at work. Maybe some of you out there can shed some light on the subjects.
I don't want anyone taking my side, so I'm going to keep it unbiased.
Tech A says: ALL gears inside of a manual gear box are turning while the engine is idling, manual gearbox is
in neutral.
Tech B says: The output shaft gear set and reverse gear are not turning while the engine is idling, manual
gearbox is in neutral; all other gear sets are turning.
Tech A says: A manual transmission will not reach normal operating temperature, during 25 deg. F ambient air
temps, simply by starting the engine and allowing the engine to warm by idling in neutral.
(Meaning, allowing the engine to warm up for like 20 to 30 minutes on a freezing cold morning)
This tech feels that the ambient air temp. surrounding the entire transmission is more than
sufficient to prevent the transmission from being warmed to operating temp.
Tech B says: A manual transmission will certainly reach normal operating temperature, while the ambient air
temp. is a mere 25 deg. F, simply by starting the engine and allowing the engine to warm by idling
in neutral. (Meaning, allowing the engine to warm up for like 20 to 30 minutes on a freezing cold
morning) This technician believes that the heat from allowing the engine to idle for 20 to 30
minutes, will be enough heat and ample time for the heat to transfer from the engine to the
transmission via the bell housing mating surface. He also maintains that the exhaust will be a
contributing factor to warm the transmission, even though the exhaust first needs to heat the 25
deg. F ambient air that surrounds the transmission.
........Thoughts ??
in neutral.
........Thoughts ??
