I am pretty sure they are different I haven't heard of a failure of
one of them other than damage.
--- In BC-BFLegacyWorks@y..., "Sam & Beth Barrett" <LEVATHIAN@s...>
wrote:
> Hmm...<Pulling foot out of mouth> So the likely hood of these
sprockets
> fitting an EJ22 open-deck is pretty low eh? The timing markers are
probably
> completely different(?).</pulling foot out of mouth> I'll have to
see if I
> can look at a couple side by side if I can in the next couple o'
days...
> -Sambo
> -----Original Message-----
> From: acroxford@h... [mailto:acroxford@h...]
> Sent: Monday, April 30, 2001 11:29 AM
> To: BC-BFLegacyWorks@y...
> Subject: [BC-BFLegacyWorks] Re: Cam Sprocket Help!
> They could be a light weight plastic type pulley the DOHC 2.5
engine
> had plastic pulleys with magnets embedded in them to actuate the cam
> sensors. This is why the 2.5 engine found in a salvage yard with any
> front damage most likely would have bent valves. Tt is a non
> interferance engine but the valves could hit even with a belt
failure.
> wrote:
> > All,
> > _CAM SPROCKET_ = The two, big, wheelie looking things with teeth
> INSIDE the
> > timing belt cover, on each side of the engine.
> > Not timing belt cover itself. If the cam sprockets were
lightweight
> plastic
> > I guarentee the EJ20R would be _the_ most tragically flawed engine
> to ever
> > come out of Japan.
> > Just for clairification, in case if anyone else was confused John,
> not to be
> > untoward.
> > I'm looking for a lightweight version of these, aluminum maybe?
> Anyone know
> > where I can find them?
> > Appologies in advance,
> > -Sambo
> > From: JohnnyG [mailto:grilla@i...]
> > Sent: Monday, April 30, 2001 4:46 AM
> > Subject: Re: [BC-BFLegacyWorks] Cam Sprocket Help!
> > The stock ones on an EJ20R are lightweight plastic... sort of a
> Bakelite
> > compound. DOHC of course...
> > John Gillon
www.clubsub.org.nz
> > ----- Original Message -----
> > From: Sam & Beth Barrett <LEVATHIAN@s...>
> > To: <BC-BFLegacyWorks@y...>
> > Sent: Monday, April 30, 2001 8:12 PM
> > Subject: [BC-BFLegacyWorks] Cam Sprocket Help!
> > > Does anyone know where I can get lightweight _Cam_ shaft
> sprockets? I know
> > > there are underdrive pulleys etc. that are made of lightweight
> aluminum,
> > can
> > > anyone direct me to some similarly built cam sprockets? I'm sure
> they
> > > exist... I just can't find 'um. Maybe with good reason (?)
> > > Thanks,
> > > -Sambo
> > > To unsubscribe from this group, please send an email to:
> > > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
