Assistance Identifying Plugs
Posted: Thu Apr 25, 2013 12:37 am
by originalcyn
I have some plugs under the driver's side dash that are not plugged in and I was uncertain what they were.
Left side of dash near the lever for the hood release
Right side of driver's side dash next to the center console
There's one more set of plugs above this second picture, medium sized black ones that look like they match, but are unplugged.
Any help is greatly appreciate! Thanks!
Re: Assistance Identifying Plugs
Posted: Thu Apr 25, 2013 12:41 am
by Someperson
green and black 1 wire each? for checking trouble codes. big-ass black connector on the right? no idea... mine's unplugged too not sure it's for anything really...
Posted: Thu Apr 25, 2013 12:42 am
by Someperson
black is for active diagnostics
Posted: Thu Apr 25, 2013 2:33 am
The one wire black plugs are the read memory plugs (checks the ecu for stored codes)
The one wire green plugs are the d-check memory plugs (checks the ecu for active codes)
The yellow plug is the select monitor plug
The big black connector is the subaru factory check connector
More info
http://surrealmirage.com/subaru/files/s ... tion15.jpg
Posted: Thu Apr 25, 2013 2:38 am
by Someperson
select monitor? and srry had em backwards
Posted: Thu Apr 25, 2013 2:40 am
The select monitor is Subaru's diagnostic scan tool. I picked one up a little over 10 years ago. It's like Vikash's scan tool, but a stand alone piece of hardware. You also need cartridges for it.
Vikash has pics of one near the bottom of the first post.
http://bbs.legacycentral.org/viewtopic.php?f=15&t=48779
Posted: Tue Apr 30, 2013 12:26 am
by originalcyn
Thanks Josh and Someperson.
Last one!
It's like 4 wires to a single plug, plus two leads?? or something....This one is pretty close to the select monitor plug. The two leads appear to have electrical tape around them.
Posted: Tue Apr 30, 2013 2:57 pm
by cj91legss
those wires not inserted into that particular plug go into that plug when you want read the seat belt error codes
Posted: Fri May 10, 2013 10:41 pm
by originalcyn
Gees, so many things that tell me what's wrong with the car. Lol. Thanks CJ.
Posted: Sat May 11, 2013 2:55 am
by cj91legss
No problem. Anything to help man.
Posted: Sat May 11, 2013 11:46 am
by James614
cj91legss wrote:those wires not inserted into that particular plug go into that plug when you want read the seat belt error codes
How many seat belt error codes could there be? I thought you needed to replace the whole motor/track assembly if something went wrong anyways.
Posted: Sat May 11, 2013 11:21 pm
by cj91legss
There are several codes, BUT the computer will only display ONE code at a time. So when diagnosing and fixing a code in the seat belt computer, You may end up with another code which means another problem. it's one of those One by One things.
