turbo coolant lines
Posted: Fri Apr 26, 2013 4:51 am
by matt j
Ok i didnt know which section to put this in but i hope this is right. I have a ej22t in my 98 impreza, i am not running a water box and im trying to hook up my coolant lines for the turbo. I have the factory port off the head as the feed, but where can i return it to? Please let me know asap thanks!
Re: turbo coolant lines
Posted: Fri Apr 26, 2013 3:25 pm
by cj91legss
the coolant line returns back into the head.
Posted: Fri Apr 26, 2013 3:36 pm
by wtdash
Hi,
EDIT: Found this post showing the coolant flow diagram HERE.
And for reference here's the NON-turbo / NA EJ22e version:
The Turbo's water pump has an extra port connected to the coolant tank for the '92-'94. The '91 turbo water pump also has one that connects to the oil cooler.
I've read over on RS25.com (more info there than here for Impreza swaps) that people either tap into the throttle body/IAC coolant lines or the heater core lines.
GL,
TD
Posted: Fri Apr 26, 2013 10:45 pm
I would suggest dumping the turbo coolant return into the heater core return line. Make sure you tap the correct line or the coolant won't flow correctly.
Tapping into the TB/IAC lines won't provide enough flow.
Posted: Sat Apr 27, 2013 2:27 am
by wtdash
Legacy777 wrote:I would suggest dumping the turbo coolant return into the heater core return line. Make sure you tap the correct line or the coolant won't flow correctly.
Thanks. I was wondering if the TB/IAC was sufficient. I'll also use the HC lines.
Posted: Sat Apr 27, 2013 2:43 pm
by matt j
i was thinking the heater core line was going to be the one just was hoping not. I tapped into the iac and tb and it didnt work at all. so which hose is usually the return line? lol
Posted: Sat Apr 27, 2013 2:53 pm
by wtdash
Scroll thru this POST on RS25.com. I 'think' the stock hoses have arrows pointing you in the right direction. Follow the hard lines on the engine to help, too.
TD
Posted: Sat Apr 27, 2013 2:56 pm
The hose coming from the heater core that connects to a hard pipe that goes under the driver's side head and to the water pump is the return line.
