2011 STi Suspension, any way to make it fit?
Posted: Wed May 08, 2013 10:44 pm
by tsbpenguin
I have an opportunity to pick up a full suspension setup from a 2011 STi w/ 1000 miles for an absolutely stupid price. Looks like one pair of the struts have a different way of mounting to the hub. Would I/could I use the hubs from the STi to make them work? Different top hats? Any other info/input?
Re: 2011 STi Suspension, any way to make it fit?
Posted: Wed May 08, 2013 10:51 pm
by PhyrraM
The front...maybe. The mounting to the knuckle will need to be modified because STIs used a different front knuckle/spindle. I'd be wary because the cars are very different weights. It's also possible that the tophat changed.
The rear...nope. Too different. Too short. Different mounting.
Posted: Thu May 09, 2013 2:11 am
I wouldn't bother. As mentioned the rear is different and if you have to modify the hell out of the fronts to fit....it just isn't worth it.
Posted: Thu May 09, 2013 6:31 am
by jamal
nope.
Posted: Thu May 09, 2013 7:30 am
by tsbpenguin
Makes sense, thanks for the info! Had to at least look into it, my buddy only wants $350 for all 4 plus sway bars...
