Constant CEL Code 35
Posted: Mon May 27, 2013 3:54 am
Hello!
For starters, I would just like to thank the kind people who freely give there time and expertise to a website like this. I seriously tour around it for hours learning about my sub, planning future projects or figuring out the current ones. So from a forum newb to the pros, you are appreciated.
Okay, now to the problem. Bought a 1990 Legacy (auto, LS) about 6 months ago with 114,000 miles on it. She's been great, and after tweaking minor things that were on the to do list, this is the big stumper. The CEL has been on since I bought the car. I quickly figured out it was giving me code 35 for a purge valve solenoid. I replaced it with a new one (Partsgeek was the cheapest if you are looking) and cleared the codes, but the light came back on. I then replaced the gas cap, and oddly the light went off for about two days then came back on. The light will stay on consistently, unless it is raining or of high humidity outside (weirdest symptom). I am getting about 5mpg less then what I should be, so would really like to get to the bottom of this. I have also tried replacing the fuel vapor canister but was no help. I don't believe it is due to a vapor leak bc if I undo my gas cap there is still pressure there giving me that hiss sound when I go to refill.
I need to replace one of my sending units which will be done this week, but other than that I don't know where to look next. I was going to try replacing the fuel vapor separator? Could this problem potentially be related to the sending unit? Anyone ever heard of the ECU not putting out correct voltage to this sensor?
Any help would be greatly appreciated!
