Fuel Line Size?
Posted: Mon Jul 01, 2013 12:27 am
by CAV3MAN227
-This might be a stupid question, as I have replaced these fuel lines in the past but, What are the sizes of the two fuel lines from the fuel filter to the manifold lines and the return line?
-Joe
Re: Fuel Line Size?
Posted: Mon Jul 01, 2013 12:44 am
by robertpaige
According to vrg3;
"The fuel hoses are 7.5mm, I believe. I have 5/16" fuel hose on my car. If you replace it be sure to use fuel injection hose and not just regular fuel hose; you need something designed to handle high pressure."
Re: Fuel Line Size?
Posted: Mon Jul 01, 2013 12:54 am
by CAV3MAN227
-Thanks for your quick reply. Sounds like where I messed up, getting the regular fuel line. Its starting to swell and wont stop leaking no matter how much I tighten it.
-Also the smaller line, which I think is the evap line, what size is that one?
-Joe
Re: Fuel Line Size?
Posted: Mon Jul 01, 2013 2:36 am
by CAV3MAN227
-Well the 5/16" hose worked perfect. No more leaks. That smaller, evap hose I will just have to do later.
-Joe
