uhg, i need help again..
Posted: Thu Jul 04, 2013 5:43 am
So I just got my new engine in and it was running fine except for the crappy idling. It would idle from between 2.5k and under 500 rpms. It had no relavence to car temperature and it was completely random. So I figured it would he the iac, so I swapped it out with the one from my previous engine since it was good. Turned the car on and taadaa, it was idling right on top of the 750rpm mark. Burped the coolant lines. Then drove around the block and got into boost a couple times and everything checked out aye-ok.
Took it out on the road and pushed it a bit and after awhile, it started feeling like it was loosing power... I checked my boost gauge while I floored it and it was boosting to 15psi (I had it set at 12psi) but it wasn't pulling at all! It was fuel cutting and I was just flooring it from 3k and it would fuel cut before I got to 4.5k rpms...
My CEL also came on and it was turning on and off while all this was happening. I'm gunna pull the codes tomorrow and see what shows up.
Any thoughts would be appreciated, thanks.
