Best path thru firewall for passenger side wires?
Posted: Sat Jul 06, 2013 8:33 pm
by free5ty1e
Hey hey,
In rewiring some things in my car, I'm wondering what you guys use when you have to run wires / cables thru the firewall on the passenger side -- is there an easy way through or should I just plan on running all wiring through the little grommet behind the pedals on the driver's side like I'd been doing? I see some rubber-booted holes through the firewall on the passenger side but they all look to be coming in behind the dash where I can't easily get to them.
Re: Best path thru firewall for passenger side wires?
Posted: Sat Jul 06, 2013 9:30 pm
by robertpaige
Yeah I always just use that little grommet behind the pedals. Ive never had to run wires to the passenger side, but I think there is a hole that you can use to access that side of the firewall. Maybe someone can chime in on that.
Posted: Sat Jul 06, 2013 11:13 pm
by kimokalihi
Is that the one below and almost behind the brake booster? That one is a real bitch to get to. I am running my boost hose and my AFR wiring through that hole and it was not fun installing that.
Posted: Sun Jul 07, 2013 12:10 am
by matt00rs25
I just drilled a hole and ran my boost gauge hose and afr wires through and sealed it up.
Posted: Sun Jul 07, 2013 12:43 am
by SILINC3R
Take the fender off and you should see a grommet
Posted: Sun Jul 07, 2013 2:01 am
by BoostedSubie
I used the hole for the AC box drain hose but I deleted my AC so don't think that would work for you.
Posted: Sun Jul 07, 2013 2:39 am
by free5ty1e
Hmm oh well back to the hole behind the pedals
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
Posted: Sun Jul 07, 2013 2:59 am
I drilled a hole through the rubber grommet where the AC lines come through. This was kind of a bitch but did work. There is a plastic grommet in the fenderwell that I ran the EGT wiring through as well.
Posted: Sun Jul 07, 2013 3:43 am
by kimokalihi
I deleted my ac too but don't think I want wiring coming through the hole where the ac hoses used to reside. I have a plug there now and a spare in case I decide to give it a try but that's right behind the downpipe and its in plain view and I'm trying to clean the bay up.
Posted: Sun Jul 07, 2013 6:22 am
by SILINC3R
SILINC3R wrote:Take the fender off and you should see a grommet
Now with more pictures
Posted: Thu Jul 11, 2013 5:50 pm
by 91Beater
I just pulled +12v for a second power outlet + stereo the other day. I picked up a grommet with a hole in the middle from auto parts store. It's labeled as Chrysler, GM or something and its like $3. Just tape around the hole on the inside to keep the engine noise out. When I had the plug removed, boy did I hear everything under the hood.
Undo the carpet as much as needed, then push the plug out. From the inside of car into the engine side, shine a flashlight. It's just by the steering.
Push something like a speaker cable or coax cable and you'll find it easily. If you need to pull from engine side to inside, tape it up to the coax/speaker cable neatly so there's no jagged edges along the joint, then pull it in.
Application permitting, I prefer this spot over the A/C drain. That one puts it right above the first catalytic converter, so its getting exposed to heat.
