Torque converter woes
Posted: Sun Aug 11, 2013 6:26 pm
by 6inarow
So I pulled the motor out of my 93 wagon, for the rear main seal and I forgot to put more fluid into the torque converter when I installed it. I start the car and idles fine. When I go to put the car in gear, it won't move! No d321, reverse, nothing. Now is the torque converter trashed, or can I get fluid into the torque converter without removing the engine again?
I know I'm a bit of a noob, but not with cars. This type of mistake makes me feel like its my first time working on a car. How could I have misses that crucial step.
Please help, and thank you in a advance.
Jon
Jon
Re: Torque converter woes
Posted: Sun Aug 11, 2013 8:26 pm
Welcome to the BBS Jon.
Did you replace the torque converter or pull it out of the trans? If not, you really shouldn't need to pour trans fluid in the torque converter. If you pulled the torque converter out, did you reseat it all the way? If you did that, and it's not working, then I'd just try pulling the torque converter out again and putting fluid in it.
Posted: Mon Aug 12, 2013 3:37 am
by 6inarow
I had another go at it today and I messed up the torque converter. I also beat up a clip on a hallow shaft. I'm going to get another trans with torque converter on Wednesday, so I'll just slop the motor and trans in as one piece.
I come from a bmw background and I'm just not familiar enough with these engines( now I am! ), and sometimes you learn the hard way.
Is it easier to install a motor and trans as one piece?
Jon
Posted: Mon Aug 12, 2013 4:41 am
by wtdash
Jon
Hi,
It depends on your tool collection- hoist/load leveler/tranny jack/etc. It's a very tight fit to put them in together, but has been done, from what I've read.
GL,
Td
Posted: Mon Aug 12, 2013 6:49 pm
If you've got a good enough hoist and someone to help then putting both in at the same time may be better.
Posted: Mon Aug 12, 2013 8:34 pm
by 6inarow
Well I got a transmission coming in on Wednesday so the car will be running Wednesday night.
Jon
Posted: Mon Aug 12, 2013 11:16 pm
by 6inarow
When the new trans gets here, do you recommend replacing the TC seal and output seal as well? Just want to do some preventative maintenance if I can
Jon
Posted: Tue Aug 13, 2013 1:30 am
by wtdash
Yes.....both of those are good to replace. BTW, if you spend some time on the USMBsite, you'll find more info on the TC and seating it and such.
TD
Posted: Wed Aug 14, 2013 3:28 pm
by 6inarow
wtdash wrote:Yes.....both of those are good to replace. BTW, if you spend some time on the USMBsite, you'll find more info on the TC and seating it and such.
TD
Oh boy! Now. My wife won't be able to get me off of more forums! Thanks for the hell, I'm getting the car prepped for the new tabs today, and back on the road she will be.
Jon
Posted: Thu Aug 15, 2013 11:38 pm
by James614
Me and a buddy tossed my new engine and trans in as one piece. May be faster, but IMO no easier than doing them separate.
Posted: Tue Sep 03, 2013 11:19 pm
by 6inarow
She is back on the road as of a week ago, but I have another thread started about my linkage issue. Fml, these cars seem more complicated then my 30 year old bimmer.
Jon
