Transmission code question
Posted: Thu Sep 05, 2013 6:09 pm
by andyyyy
I have a 92 turbo wagon and just got done swapping out the tranny and am getting an error code from the power mode light. It's flashing 16 times when ever I start up the car. Everything seams to be working normally but i cant find what code 16 is. If any one knows where to find this code or what it is it would help a ton. Thanks
Re: Transmission code question
Posted: Thu Sep 05, 2013 6:37 pm
by wtdash
Hi,
Here's the link....http://www.surrealmirage.com/subaru/trans.html
Post back what codes you find.
BTW, You can use the Search - Google bar @ the top to find most everything on here.
GL
TD
Posted: Fri Sep 06, 2013 1:22 am
by andyyyy
Ok I checked it and it was showing 33 which is the 2 speed sensor, which makes sense because my speedometer stopped working. When you turn on your car and the power light is flashing that is not a code which is what threw me off it blinks 16 times no matter what.
Posted: Fri Sep 13, 2013 2:26 am
Check the speedo cable or more likely the base piece for the speedo cable. It screws into the trans and commonly fails.
