Manuel shifter assembly plate?
Posted: Mon Sep 30, 2013 1:01 am
by Tommio RS
Hi there everyone!
I have a simple/maybe difficult question.
In a factory 5mt 1993 legacy SS the rubber shifter seal thing, does it have a metal ring/rectangle plate?
Because i removed the old auto shifter and it nicely bolts to the body with a rubber seal with the actual shifter assembly as this plate.
I would think this seal would get the same treatment for both MT and AT cars?
This NOT the shifter boot for a MT car!!!!
Tom
Re: Manuel shifter assembly plate?
Posted: Mon Sep 30, 2013 4:27 am
by wtdash
RU referring to this part:
If so, RU stating the AT metal bracket doesn't fit on the 5-speed? I don't remember what I did on my swap.
Td
Posted: Thu Oct 03, 2013 12:35 am
by Tommio RS
Well from what i have seen and worked with the 5mt should have a diff plate to hold the rubber seal.
The AT shifter is that plate/ total shifter assembly.
So i dunno. I think im going to go hit a wrecker and scope out some 5mt subi's!
Posted: Wed Oct 09, 2013 5:18 am
Yes, there should be a separate metal plate that keeps the boot clamped to the body.
Posted: Thu Oct 10, 2013 12:12 am
by James614
Hmmm. I need this metal plate too, apparently. I though the rubber boot just screwed in there :-/
Posted: Mon Oct 28, 2013 2:59 am
by Tommio RS
Yes.
There is a MT shifter boot plate for any MT subaru!
I just went to my dealer and got me the correct one for my car!
Its probably the same boot plate for any MT car.
