				Is 17x10 to wide?
				Posted: Thu Dec 05, 2013 8:27 pm
				by Nibbib
				So my question is just like the title is 17x10 offset of +20 to wide for are first gen legacy's I'm not too worried about fenders. My concern is the back of the rim rubbing on my suspension as of right now I don't have coilovers but I'm hoping to buy some soon before I run the rims.
Has anyone ran this wide of rim before with +20 or close to it?
				Re: Is 17x10 to wide?
				Posted: Fri Dec 06, 2013 7:12 pm
				by macipusy
				It is possible to do some measuring and calculations for a ballpark estimate.
Here is the visual breakdown of how offset works (just for reference).
You can measure the distance between the strut and your current inner rim lip.
Stock rims should be +53 offset, I believe. You should know your stock rim width and diameter.
Sketch your wheel  and the wheel you want in the same manner as the photo. Analyze the sketch in relation to the strut spring perch location which most encroaches your wheel. Just standardize your units between the wheel width (inches) and offset (mm). You should be able to figure out how much more the new wheel will encroach into the strut. There is an extra dimension (Y axis) to think about when jumping in rim sizes.
One hard thing to account for with this method is the shape of a new tire, especially a different sized one.
You can always dent the spring perch if it's close or barely touching, or wheel spacers.
				Posted: Fri Dec 06, 2013 11:10 pm
				by 86BRATMAN
				I think the real question here is how much of your fender are you willing to lose.
				Posted: Sat Dec 07, 2013 1:19 am
				by Nibbib
				well I'm not planning on running any wider rim till i can also install coilovers. and i have seen the diagram before and found a website where you can put to rims together.
heres that website:
http://www.rimsntires.com/specs.jsp
and about how much fender im willing to lose, i have been thinking of going with some 240z fender flares.
the only thing is the rear doors would be a pain to make work...
but here is what they are:
http://www.zforceproductions.com/?optio ... &Itemid=60
				Posted: Sat Dec 07, 2013 6:19 am
				by GClark
				I ran a17x9 35+ and had to have the fenders pulled an inch.  They still didn't fit right.
Now I have 17x8.5 42+ and I think it fits perfect.
Destroy your fenders if you want to, 17x10 is going to fit pretty poorly.  I don't know if it's going to hit the coils, mine didn't but I think it was pretty close.  Might as well try it.
				Posted: Sat Dec 07, 2013 10:16 am
				by Nibbib
				Hmmm I really like the pic of the Goldie's lol idk I just found a set in Seattle area that are bbs rs reps for 600 shipped it's just the question is how much ill need to destroy my fenders but I'll see lol
These are the rims:
http://seattle.craigslist.org/see/ptd/4204541996.html
				Posted: Sun Dec 08, 2013 7:58 am
				by subaru_styles
				theres a silver sedan thats running 18x10's in portland
				Posted: Wed Dec 11, 2013 10:56 pm
				by Nibbib
				Does it have big side skirts and lip and rear spats?
				Posted: Mon Dec 30, 2013 2:37 am
				by Nibbib
				GClark wrote:I ran a17x9 35+ and had to have the fenders pulled an inch.  They still didn't fit right.
What brand are they?
