92 Legacy SS - Resurrected!
Posted: Tue Dec 10, 2013 11:15 pm
This is a very original 92 Legacy SS that has fairly low mileage (134k) but was driven with no maintenance for a long time. I am bringing it back to life. I bought it with a seized cam on the passenger side head and some body damage, not to mention the years and years of accumulated dirt and grime over the entire car. It is all stock except for seats from a '94 SS and an Exedy lightweight flywheel paired with a new Exedy clutch.
Here's the problems as purchased and related fixes:
Seized cam due to absolutely bungled timing belt job, replaced head/retimed and it runs great.
No locks worked on the entire car, removed all locks and cleaned/lubed/removed broken-off keys to make them all work.
Dented door replaced with junkyard winestone door.
Rear quarter window broken to get into the locked car at some point, replaced with junkyard rear quarter window.
Bad alternator and other minor stuff, replaced with good junkyard parts.
5-speed was shifting poorly, changed fluid and all is well (probably still had factory fluid, and was over a liter low!)
Stock stereo not working, replaced with 06 WRX 6-CD changer.
Power antenna broken, replaced with amplified under-dash antenna.
Sunroof taped up, needed resealed.
CV axles shot, one was original and the other had a torn boot, Replaced with new axles.
Problems left to fix:
Paint on hood and spoiler is no good, I will repaint them in the spring when the weather warms up.
When I first got it home, with the door dent.
