Aftermarket weld in cats
Posted: Mon Dec 23, 2013 6:29 pm
by sleepinsuby
Been looking into taking off my stock catted dp as I think it may be all broken up inside and clogged. I have a Perrin devorced dp I'm thinking of putting on and just adding a high flow weld in cat in the mid pipe. Anyone ever used one? I get a idle and high idle sniffer test for emissions and need the cat to pass. Been looking into this
http://m.summitracing.com/parts/vpe-710 ... Mgod2TwAUg think it will flow good and its ment for obd1 car. Any other obd1 high flow cats anyone knows of that work for around that price?
Re: Aftermarket weld in cats
Posted: Mon Dec 23, 2013 7:37 pm
by Alphius
Any sort of high-flow weld-in cat should work fine, there's plenty of options out there. I prefer the MagnaFlow spun-metal substrate like here:
http://www.ebay.com/itm/3-Magnaflow-Uni ... 0847989857
My '94 Legacy passed sniffer emissions tests just fine with a catless exhaust here in WA, but we don't have an inspection or visual test at all.
Posted: Thu Jan 23, 2014 2:25 am
by Pythonmsh
My emissions were just fine without cats. I actually scored better without them. The problem is they did a visual test. You should be good as long as they don't do a visual test.
