Page 1 of 2
Picking up some Red STI Strings/Struts
Posted: Fri Jan 10, 2014 12:59 am
by shoefean
So I'll be picking these up in a few days and wanted to find out exactly what parts/top hats are needed for these to fit.
The car they are going on
And any pics of other leggys running the same suspension would be greatly appreciated.
Re: Picking up some Red STI Strings/Struts
Posted: Fri Jan 10, 2014 3:23 am
by devilzdriver
I had the exact same set up except with tein springs, then swapped for WRX springs. If memory serves me correctly i didnt have to do anything. Except mount it.
Posted: Fri Jan 10, 2014 5:05 am
by 86BRATMAN
Gotta swap the rear top hats for 90/91 legacy rears, then they'll bolt right in, assuming you have 04 STi struts.
Posted: Fri Jan 10, 2014 5:55 am
by jamal
Definitely 04 sti. The rear tops are not the right bolt pattern for the chassis. Use 90-91 mounts or you are going to have to drill/file the holes.
Posted: Sat Jan 11, 2014 9:02 pm
by devilzdriver
86BRATMAN wrote:Gotta swap the rear top hats for 90/91 legacy rears, then they'll bolt right in, assuming you have 04 STi struts.
Your right!
Posted: Sun Jan 12, 2014 12:14 pm
by shoefean
These are 05 sti suspension if that changes anything! Anybody have any sedan pics so I can see how it's going to look?
Posted: Sun Jan 12, 2014 4:32 pm
by 86BRATMAN
It changes the way the fronts mount up. You'll have to make a new lower hole in the strut, there is a write up somewhere on here.
Posted: Sun Jan 12, 2014 6:53 pm
by cj91legss
I thoight 05 sti suspension was black tho?
Posted: Sun Jan 12, 2014 9:45 pm
by 86BRATMAN
I'm going with someone painted them red, it's peeling all to hell.
Posted: Sun Jan 12, 2014 10:25 pm
by cj91legss
shoefean wrote:These are 05 sti suspension if that changes anything! Anybody have any sedan pics so I can see how it's going to look?
Check my build journal.
Posted: Sun Jan 12, 2014 10:26 pm
by cj91legss
86BRATMAN wrote:I'm going with someone painted them red, it's peeling all to hell.
Just noticed that
Posted: Tue Jan 14, 2014 8:20 pm
by shoefean
I ended up passing on these cause the dude was asshat. i did pick up some used Tein springs for an 02-03 WRX. Will those fit my Stock struts or will i need WRX struts for it to work? Thanks for the info
Posted: Thu Jan 16, 2014 6:50 pm
Can you remind us what year Legacy you have?
Posted: Thu Jan 16, 2014 8:31 pm
by shoefean
94 legacy sedan
Posted: Fri Jan 17, 2014 1:35 am
by cj91legss
If youre still curious about ride height, you can check my build journal since I have the 04 red struts and springs on my ss.
Posted: Fri Jan 17, 2014 9:19 pm
by shoefean
cj91legss wrote:If youre still curious about ride height, you can check my build journal since I have the 04 red struts and springs on my ss.
Thanks but i passed on getting those Red's. I'm now curious what 02-03 Tein springs look like on stock legacy struts cause i have a set sitting in my garage...
Posted: Fri Jan 17, 2014 9:28 pm
by cj91legss
I don't know what the ride height will be on your sedan. I don't know if the ride height would be reduced evenly compared to OEM 02-03 springs. When I had 0203 stock springs on my car the rear sat lower than the front and I wasn't happy with that. So if you get the tiens, be prepared to have the back sit lower than the front. Obviously on a wrx the ride height would be the same for the most part, it was just different on my car. BUT this was on my 91 wagon.
Posted: Thu Jan 30, 2014 8:40 pm
by shoefean
Okay... Finally decided that i want KYB AGX's so i sold the Tein springs and picked up some H&R springs. My question now is what parts will i need. Will i be able to use my current top hats or will i need 90-91's?
Posted: Thu Jan 30, 2014 8:58 pm
by robertpaige
If the strut/spring is for a WRX you will still need to use the 90/91 top hats in the rear, fronts still bolt right up.
Posted: Thu Jan 30, 2014 9:05 pm
by mike-tracy
What did those come off? If its a gc8 then you don't have to change anything.
As an aside, the 90-91 rear tophats only work with certain year impreza springs, the sticky has the info.
Posted: Fri Jan 31, 2014 8:08 pm
by shoefean
Those struts came off of a 98 outback. And after checking the kyb website, they have 90-94 legacy agx struts. Would i need new top hats or could i use my old ones?
Posted: Fri Jan 31, 2014 8:45 pm
by mike-tracy
You can reuse your tophats.
Posted: Sun Feb 02, 2014 6:13 am
by devilzdriver
When i built my suspension the second time, i quit using the stock crap and upgraded to group N's let me tell you noticeable difference.
Posted: Sun Feb 02, 2014 9:36 am
by mike-tracy
Devilzdriver, do you have a source for group n rears for our cars? Fronts are the same as later cars, but the dealership told me they couldn't get rears anymore (gc8 application).
Posted: Sun Feb 09, 2014 12:21 am
by shoefean
So i purchased some KYB GR-2's front & back. My question is, will i be able to use my existing top hats or will i need new ones?
