EJ22e sudden loss of boost at 5500rpm
Posted: Sun Jan 19, 2014 8:28 pm
I have just an ej22e with a td04 running wastegate pressure of 6psi and no tune. It has run flawlessly for the past 5 months or so.
The other day I decided to put a turbo water pump on it so the headers would clear the water pump without the use of stacked gaskets. I took off the fmic, some piping, and the water pump. Put the water pump back on, fmic back on and all the piping. At the same time I also put a new BOV on too.
The car pulls just like it use to at a full 6psi up until 5500rpm exactly then it falls on it's face and will BARELY accelerate and it's at 0PSI. It's like it switches to N/A but 3 times as slow after 5500rpm.
It idles fine and runs fine up until 5500rpm. I figured it was the BOV so I messed with the preload and even put the other BOV back on and it still does the same thing. I then removed all the intercooler pipping and put it all back on just in case one the the flanges weren't mated up properly... And still the same thing. The last thing I can think of is my ghetto ass intake. It's a 90" silicone pipe from the turbo and then it's duct tapes to the stock intake. It has worked fantastically for the past 5 months. I don't know why It would just cause a problem.
Does this sound like it could be the intake? I've ordered an intake for it and I'm just waiting on it to arrive in the mail.
This is kicking my ass!
Oh, I'm also running no tune. So it can't be my tune!
