overheating questions
Posted: Fri Feb 21, 2014 11:53 pm
by carterg31
hello, I have a 91 legacy with a rob tune 550 injector 06 wrx intercooler and a td05 turbo from a jdm sti. Stock radiator other than it is for an automatic and im running manual now. i also have the wrx coolant tank relocate done thats described on here.
last week i ran it at its first auto cross. my question is that i was running hot and my coolant overflow bottle was overflowing itself. Any suggestions? ideas on keeping the temps down in an autocross setting.? is its air in my coolant lines ? do i need better coolant ?
Re: overheating questions
Posted: Sat Feb 22, 2014 1:51 am
by mike-tracy
Do you have a Subaru thermostat? If not, replace it asap!
Posted: Sat Feb 22, 2014 2:00 am
by carterg31
Yes I have a new oem thermostat
Posted: Sat Feb 22, 2014 2:20 am
by rallyak
Are the fans working? Is there debris in the radiator or condenser (if you have a/c)? How dose you heater work, a plugged heater core will make the car to over heat. (Learned that from personal experience)
Posted: Sat Feb 22, 2014 2:34 am
by carterg31
Fans are working, heat works well, I still have ac I have not tried the ac . There could be debris in it . I just refilled after timing belt and seal job . Took quite a while to burp it, but I think I got the air out . Brand new oem water pump as well .
Posted: Sun Feb 23, 2014 8:44 am
by carterg31
bump.
Posted: Sun Feb 23, 2014 1:21 pm
by James614
Combustion gases escaping into the coolant? Maybe you HG leaks under high boost.
Posted: Mon Feb 24, 2014 1:09 am
Have you experienced any overheating issues while driving normally and not at the autox? Do you drive spiritedly normally? What I'm trying to get at is would your car normally see the more agressive driving experienced during autox events during normal driving.
Posted: Mon Feb 24, 2014 7:17 am
by carterg31
No it does not overheat during normal driving. I drive the car spirited every now and again during normal day to day driving, but the car is a designated autocross and rallycross car.
Posted: Mon Feb 24, 2014 5:11 pm
Is this the first time you've experienced issues?
Posted: Thu Mar 06, 2014 4:57 am
by carterg31
yes, the first time it overheated , but that was the first race with the car since Iv upgraded it.
Posted: Thu Mar 06, 2014 6:44 pm
If this was the first time after the upgrades then I would look over how you have the WRX coolant tank piped up and all the other modifications to make sure something didn't get missed.
Posted: Sat Mar 08, 2014 3:16 am
by wtdash
^+1
Hi,
I've never had overheating problems w/either my current '93 SS or my swapped '90 - and it was running the stock NA radiator - both were Auto-X'd. I'd look for any 'plumbing' issues.
Miles on the stock engine?
Td
Posted: Wed Mar 12, 2014 9:27 am
by carterg31
ok ill check over the plumbing. Possibly take some photos of the wrx tank relocate plumbing. I remember not being 100 percent confident in the re using of existing lines near the back of the drivers side head. as always thanks for the help. i will return with news as soon as i can
Posted: Sat Mar 15, 2014 7:55 am
by carterg31
Sooo . Think iv solved it . Broken radiator cap on my turbo coolant tank ... Thanks for all the info once again.
