rear endlink
Posted: Mon Mar 10, 2014 5:51 pm
by 208ss
anyone one know of a better option than stock rear endlink for a 91 ss? i know its not the same as 93+.
Re: rear endlink
Posted: Mon Mar 10, 2014 7:30 pm
by rallyak
I made my own from a 3/4 dodge ram front sway bar link. It eliminates the sway bar bushing that you can't find and all make noise when old. I cut the new end link and shorten it a little. Looks like this:
http://m.ebay.com/itm/290670819934?nav=SEARCH
Personally I would buy wreaking yard ones, mine came off my wife's truck and at 300k they were still in good shape. And the link is way overkill for the rear sway.
Re: rear endlink
Posted: Wed Mar 12, 2014 5:58 pm
That looks like a pretty good option!
The other option is to convert to the newer style lateral links so you can run the newer style end links.
Re: rear endlink
Posted: Thu Mar 13, 2014 12:53 am
by 208ss
That seams simple going to order rear lateral links
Re: rear endlink
Posted: Thu Mar 13, 2014 6:00 pm
Getting the rear lateral links off can sometimes be challenging if you have a bit rust. There is a long bolt that ties the lateral links to the hub and that can sometimes be a pain to remove.
Re: rear endlink
Posted: Thu Mar 13, 2014 7:33 pm
by 208ss
I work in a shop with a lot of tools.. so I hope it goes smooth . There's not a lot of rust if any
Re: rear endlink
Posted: Fri Mar 14, 2014 6:15 pm
Ok, good luck!
