front mount 93 legacy
Posted: Wed Apr 02, 2014 5:54 am
by nosyt
Well I posted these photos in my build thread but figured id post them up here for people looking for options.
This is a GC impreza kit from cx racing modified the piping to run behind the headlights instead of out the fender. Very little of the bumper beam had to be removed and stock hood latch will still work
Re: front mount 93 legacy
Posted: Thu Apr 03, 2014 6:03 pm
How much did you have to trim below the headlamps?
Posted: Thu Apr 03, 2014 6:17 pm
by sqc151
for less bends, drivers side pipe goes to turbo, pass side goes to throttle body.
this will eliminate 180 degrees of bends on the back side of the engine.
kinda like this.
(i had a rotated intake setup. but you can see how the back piping is straight to the turbo. pass side would only need one 90 degree bend on your setup)
Posted: Thu Apr 03, 2014 6:43 pm
by ride_child
sorry to hi jack but sqc, what intake manifold is that? i feel like ive seen the plastic ones i guess i just didnt realize they have that crazy side mounted inlet! thanks!
Posted: Thu Apr 03, 2014 7:40 pm
by PhyrraM
2005-2009 Legact GT/Spec.b/Outback XT
2008-2013 WRX (not STI)
2009-2012(?) Forester XT
Posted: Thu Apr 03, 2014 8:02 pm
by sqc151
ride_child wrote:sorry to hi jack but sqc, what intake manifold is that? i feel like ive seen the plastic ones i guess i just didnt realize they have that crazy side mounted inlet! thanks!
05 LGT
Posted: Fri Apr 04, 2014 3:39 am
by ride_child
thanks guys!
Posted: Fri Apr 04, 2014 5:38 am
by nosyt
I dont like running the throttle body pipe over the turbo heats up the pipe right before throttle body. The 180 really isnt that restrictive
Posted: Fri Apr 04, 2014 6:30 am
by sqc151
Turbo heat blanket
Wrap intercooler pipe.
or just rotate intake manifold...
j/k... nice job man.
What turbo you running?
Posted: Fri Apr 04, 2014 7:21 am
by nosyt
Vf37 twinscroll. This is a ver 8 sti swap using a 2.2 turbo block with wiseco pistons and scat rods and a few other goodies
Posted: Fri Apr 04, 2014 3:29 pm
by sqc151
nice!!!....^^^^
Posted: Fri Apr 04, 2014 3:47 pm
by ride_child
double nice!!
