bizzare ignition lock problem
Posted: Tue May 13, 2014 12:59 am
I dunno what's going on.
The key will not go in all the way, only half way in.
Not enough to turn the key or defeat the steering wheel lock.
The first time I fixed it by just violently turning the wheel back
and forth against the stop and the key slipped in.
It happened again today so I took most of the column cover off.
I was running late so I jut kept trying the key as I worked and
eventually it worked as normal. I didn't get to see what was up inside.
I know the car had an aftermarket alarm in the past that was then removed.
I'm wondering, could it be the key is just too worn?
Should I skip straight to getting a new ignition cylinder?
