Rebuilt Motor, Won't Start
Posted: Fri Jun 20, 2014 5:36 am
Hi guys,
I just rebuilt my ej22T. Main components replaced as follows: crank and rod/main bearings, piston rings, oil pump, and gasket kit. I used all OEM parts.
Rebuild went really well, and I installed a RobTune 550 ECU and 4to2 Converter, N/A fuel rails, sti yellow tops, VF39, and JECS MAF.
I left all three connectors behind the battery un-plugged to prime the motor and make sure it didn't sound like a bunch of metal being thrown into a recycling bin. I turned it over and it sounded great, so I plugged in the connectors and turned the key forward. The car immediately acted like it was in test mode, lots of relays clicking, erratic check engine light, and cooling fans clicking on intermittently. I turned it off and made sure the connectors were not connected and it was not in test mode. They weren't connected, it wasn't in test mode. Tried to start it, it cranked fine again but wouldn't fire. I had spark and fuel pressure, so I thought it could be an ECU issue.
The next day I decided to take out the converter and 20g ECU and plug in my old ej22t ECU and try to start it with the JECS MAF and sti yellowtops. Same story, cranked but wouldn't fire. Had spark and fuel, again. I figured this was a long shot because of the bigger MAF and Injectors, so I swapped the old MAF and old injectors/fuel rails back in. Still the same story, spark and fuel pressure, won't fire.
Moral of the long story is that my car is back to the way it ran when I pulled it into my garage to pull the motor. And now it won't start, but I still have spark and fuel.
I'm stumped. It now throws codes 35 and 49 with the stock ECU. I had the purge solenoid removed since I was going with the Robtune, so the first time I tried to start it the solenoid wasn't there. Same story with the MAF, I tried to start it with the JECS but it now has the correct MAF. I assume neither of these codes would stop it from starting though, is this correct? I disconnected the battery for a while but it won't clear the codes.
My first thought was timing, but I've done a few timing belt jobs and never had a problem. I checked it anyway, and it was indeed correct. I took it off and counted the teeth, it was still correct, so it's back on and it's right. I also have 12v to one pin and 5v to the other on the car side of the MAF plug. If I'm reading the diagram right this is also correct.
Any ideas on where to go next? It's got spark, fuel, correct timing, what more does it need? I'm thinking about going to the junkyard and looking for another coil, ingnitor, and MAF and replacing them one by one. How would they go bad from being removed and installed though?
Sorry for the ramblings...any help is greatly appreciated!
Thanks,
Keats
Thanks,
Keats
