boost control solenoid clicking/ car backfires
Posted: Mon Aug 11, 2014 7:39 pm
So i think i have a combination of things going on. I have checked for CEL and nothing. I just replaced the O2 sensor (CEL was on for it). The car is pretty sluggish and once it starts making boost it will backfire every now and again. Also a weird thing I am fixing the brake lines (rusted out) and have the back seat out of the car. For whatever reason I decided to check the wiring on the fuel pump and when the car is on the fuel pump wires feel hot to the touch.
Now with the BCS it will click back and forth when the key is in the on position. Also the fans on the car go on and off.
this is the car
http://bbs.legacycentral.org/viewtopic.php?f=9&t=22345
Now I was thinking it was the gas, but I have emptied the tank one time before and put new gas in and still the same issue. Compression is fine and no unsual subie noises.
Also i keep looking for it, but how do you check for CEL. I connected the black connectors and the check engine light just flashes at me. I keep reading something about green connectors?
this is the car
