help!! check engine light. cant clear codes
just finished 5 speed swap on my 94 tleg and my check engine light is on I ran the codes and im getting 22(knock sensor) and 51(neutral switch) I replaced the knock sensor and redid the wiring and im still in limp mode I have tried a number of thing to clear my codes nothing is working. any ideas on what it could be?
Re: help!! check engine light. cant clear codes
bad ecu? both of those circuits are directly wired to the ecu.
I would swap in a known working ecu
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Are you sure you've verified all the wiring and the neutral switch?
Does the knock sensor code come up in the active diagnostic mode with the green connectors?
