liberty engines
Posted: Mon Feb 10, 2003 3:42 am
by teaguespeed
why did the libery rs engines have so much more power than our legacys?
Posted: Mon Feb 10, 2003 4:29 am
by Mark Ward
To start...
DOHC, different mapping, better flowing heads
Mark
Posted: Mon Feb 10, 2003 5:41 am
...Air-water intercooling...
Posted: Mon Feb 10, 2003 7:28 am
by vypa
im curious... is there a way to switch our engines over to DOHC? (ie diff heads thatll fit)
Posted: Mon Feb 10, 2003 2:04 pm
by IggDawg
With some work I'm pretty sure you can use DOHC heads from a pre-99 EJ25. I gather the water passages need some work and there's a small issue with there being a slight difference in the bore of the head and the piston (larger on the head) but neither of these things present a major challenge. I've heard this setup is good for some huge numbers. well beyond the ~350hp limit of the pistons. The EJ22 is a monster if you get it to breathe right.
Posted: Mon Feb 10, 2003 6:01 pm
Posted: Mon Feb 10, 2003 6:27 pm
by IggDawg
If one was so motivated to do this sort of swap, you could assume they were in it for high numbers. If they used super-strong 8.5:1 pistons, they'd still end up with a CR more than they started with. not 8.5:1, but still better than 8:1. not that there's anythign wrong with 8:1
I certainly don't think I'll ever go this route, but I'd lvoe to hear the stories of those that have. I'll be happy with 230hp. that's my goal, and I think I can do it without new heads.
Posted: Mon Feb 10, 2003 9:12 pm
by boostjunkie
I do have a set of DOHC heads from my busted engine. However, I've also heard stories of the combination dropping CR to 7.7 to 1. Now is there a way to mill the heads down to increase the ratio? I know there are limitations to how much you can shave off the heads, but will those limitations be affected by the different pistons in the turbo block?
Posted: Mon Feb 10, 2003 10:07 pm
by IggDawg
I'd say just swap the pistons. is that a drop from 8.0 to 7.7, or 8.5 to 7.7?
Also, if you mill down the heads too much it can screw with timing IIRC. less distance the belt has to travel. At some point the tensioner pulley runs out of play. I don't know how far that is, tho. also, air passages can get "crimped" if you shave off enough that smooth curves get cut a little short so you have passages that meet improperly.
All this is speculation. I'm just visualizing.
Posted: Mon Feb 10, 2003 10:11 pm
by boostjunkie
IggDawg wrote:I'd say just swap the pistons. is that a drop from 8.0 to 7.7, or 8.5 to 7.7?
It's a drop from 8.0 to 7.7 . . . using the DOHC heads and the turbo block. As for pistons, I thought the that cylinder widths were different?
Posted: Mon Feb 10, 2003 11:51 pm
by IggDawg
I mean getting aftermarket 8.5:1 pistons. I'm pretty sure someone makes them. I'm figuring if someone needs the extra breathing of the 2.5L heads, they're prolly gonna need new pistons at that point too. I could be wrong tho. happend once bafore back in '82.
Posted: Tue Feb 11, 2003 1:03 am
by Mark Ward
Does anyone know of the EJ20T heads will fir the 2.2 bottom? I happen to have the heads etc from my old motor sitting in the shop...
Mark
Posted: Tue Feb 11, 2003 3:26 am
by boostjunkie
If they're the same design as the new WRX heads then they'll work. Better yet, as people have noted with the USDM wrx heads, you'll be able to keep the 8 to 1 compression ratio!!
You lucky bastard!!
Posted: Tue Feb 11, 2003 3:27 am
by boostjunkie
FWIW, the Liberty RS heads flow better than the wrx heads.
Posted: Tue Feb 11, 2003 4:04 am
Posted: Tue Feb 11, 2003 5:02 am
by vypa
so it seems more likely that it might bolt right up to the N/As with a bit of work? and the cams should be ok... right?
Posted: Tue Feb 11, 2003 5:44 am
by Mark Ward
So...
What would they be worth?
They use the 2.5 timing belt...
Mark
Posted: Tue Feb 11, 2003 2:04 pm
by boostjunkie
Legacy777, I've read that writeup before (it's on DLC's website, correct?). Anyways, I think that only pertains to the 2.5L heads, and not the wrx heads. I could be wrong, though.
Posted: Tue Feb 11, 2003 2:50 pm
Yeah it pertains to the 2.5 heads.........were you guys talking about the 2.0 heads??
Guess I missed that......
Posted: Tue Feb 11, 2003 3:02 pm
by boostjunkie
We started talking about the 2.5L heads, but then someone posted that they had wrx heads . . . *shrug*
Posted: Tue Feb 11, 2003 5:15 pm
by vypa
also... what about the heads from the new WRX STI? the 2.5 turbo... would those heads maybe be a good option for those of you that have the EJ22T?
Posted: Tue Feb 11, 2003 5:45 pm
by IggDawg
Those are AVCS heads. without an AVCS capable ECU, they might get a little weird I presume.
Posted: Tue Feb 11, 2003 5:48 pm
by vypa
i forgot about that igg
good point
Posted: Wed Feb 12, 2003 1:40 am
by Mudpup
Anyone know specifics on the control signal(s) for AVCS, ie. could it be controlled with a GPO from Tec II/Tec III? Or even some home grown control ckt?
