What do all these symptoms point to?
Posted: Wed Dec 10, 2014 3:33 am
Okay, got a tough one here. I will spell out every relevant detail I can think of and see if we get anywhere. I have thought about this over and over in my head and can't come up with an answer. I've also searched the forums but no luck.
The car is a '90 LS with 135,000 miles. It is an automatic.
I bought some RS springs this past weekend and threw them on Sunday evening. We went through the process as normal, jacked up the car, got it on jack stands, removed the whole strut tower with spring, replaced it and reassembled. I did not chuck the wheels and was working on a notable incline. I put a jack stand on a piece of the sub frame behind the rear diff while doing the rear springs. I put jack stands directly on the frame when in the front. Also the e-brake was on the whole time.
When we finished, went to back out of the driveway and wasn't able to budge. It was as if the engine completely wasn't engaging with the tranny. After toying for a second, I figured out I could rev up slightly and it would catch and jump forward then completely disengage. The best way I can describe the disengaging was like a clutch that will slip but opposite a normal slipping clutch: when I hold a steady rpm, it disengages, but when the car is under a load such as heavy throttle or climbing a hill, it holds strong. Other notable things would be that when it disengaged and jumps in rpms, the speedometer climbs with the rpm (as if the transmission is still rotating at those rpms?). If I accelerate hard when it engauges, I can cycle through all gears just fine, I just have to be accelerating fast. When placed in park with the engine on, all I get is a harsh grinding sound and I have to pull it out. When placed in park with it off, then turn back on, it doesn't grind, but it also doesn't hold the car in place.
I know FOR SURE that there was no popping or sudden shift or anything while jacking and releasing. I also tensioned all tires once they were on the ground. Fluids are full and correct type. I am not the most familiar with how these drivetrains work.. but should I start with the front diff? Change fluids and pray real hard? Any suggestions?
