My check engine light is not working.
eclipseguy
My check engine light is not working. I have checked, swapped out the bulbs. That did not work. I changed out the gauge cluster hoping that was the problem but no luck. I would like to check my trouble codes but with my cel not working I don't know how to pull the codes. Is there a trick to bypass the cel and get the codes? Thanks for your help.
BAD SPELLERS UNTIE!!!!
Re: My check engine light is not working.
Have you checked the fuse? I believe it #14 and it will run with it blown or missing.
Charles
eclipseguy
I checked the EGI unit AT unit (#14) it is there and not blown. I have a idle issue that i can't locate. Any way to use a analog voltmeter or a led light to pull the codes with?
eclipseguy
