converting awd 5mt to fwd by bolting on rear section fwd 5m
Posted: Sat Jan 31, 2015 8:10 pm
by jroth100
Can you convert an awd 5mt to fwd by bolting on the rear section fwd transmission to it. I am needing to replace my fwd 5mt and was told that this may be any option.
Re: converting awd 5mt to fwd by bolting on rear section fwd
Posted: Sun Feb 01, 2015 8:54 am
by RoughDiamond
Iirc, you need the shorter main shaft as well, so basically you're tearing apart both trans to cobble one together... I'd just find the same type and swap it in..
Posted: Sun Feb 01, 2015 9:03 pm
by zeke
If I'm not mistaken the FWD trans has a different final drive ratio also
Posted: Mon Feb 02, 2015 1:05 am
Yes, the FWD does have a 3.7 final drive vs. either a 3.9 or 4.111 in the AWD.
Posted: Mon Feb 02, 2015 8:01 am
by mike-tracy
I'm gonna go on a limb and say no-one has attempted this, at least on this site. ;) Final drive would be irrelevant (if it's possible), since you aren't matching to a rear diff. Unless the point of the exercise was to get the tallest gearing possible.
But, and here's some more speculating, if you could swap an awd to fwd, you could swap over the 3.7 FD ring and pinion over as well.
Posted: Mon Feb 02, 2015 3:00 pm
by 86BRATMAN
Posted: Mon Feb 02, 2015 4:24 pm
by zeke
I read that first post wrong I thought he was trying to convert it to awd.
Posted: Sun Feb 08, 2015 11:17 pm
That's pretty impressive!
Posted: Mon Feb 09, 2015 1:18 am
by 86BRATMAN
There are kits available to do the same, but they aren't cheap.
Posted: Fri Jul 10, 2015 10:35 pm
by smagg26
that's awesome! I wanted to do this glad to know there is a walk through and kits.
