Car won't turn off
Posted: Mon Mar 23, 2015 3:15 pm
Hello, I have a 1994 legacy bc sedan, auto awd non turbo, I've developed a small issue, I can remove the key from the ignition, and the car still runs, also the ignition stays on constantly and will sit there with the dash lights on and prime the fuel pump, I've removed the ignition and it still does this even when there is not ignition, anybody got ideas? Like a ignition relay?
