Sunroof opens but not closes
Posted: Sun Apr 05, 2015 9:21 pm
by dscoobydoo
i have been trying to figure out my problem. May be a relay issue. Or not.
If I push the open button it opens.
Up and close do not work.
Thoughts?
Re: Sunroof opens but not closes
Posted: Sun Apr 05, 2015 9:55 pm
by SILINC3R
Can you push it to get it moving? Do you hear it trying to do anything? If anything I would say its the switch
Posted: Mon Apr 06, 2015 2:53 pm
by cj91legss
Bad switch or computer. If you need either, message me.
Posted: Tue Apr 07, 2015 2:01 am
by dscoobydoo
It opens fine but no noise on close. I will multimeter the switch and see.
Posted: Tue Apr 21, 2015 10:39 pm
by dscoobydoo
Not the switch. Thoughts
You have a good spare computer?
Posted: Wed Apr 22, 2015 12:30 am
by Alphius
Take the relay box out (above headliner on rear passenger side) and resolder every joint on that circuit board. I've fixed several sunroofs in these cars by doing that.
Posted: Wed Apr 22, 2015 12:38 am
by cj91legss
I do have a spare. It's yours as long as you come get it drew.
Posted: Thu Apr 23, 2015 7:45 am
by Binford
Hold the close button with one hand and hit the center of the headliner behind the sunroof opening with the other. I've had several with that issue!
Posted: Thu Apr 23, 2015 11:04 pm
by Alphius
Binford wrote:Hold the close button with one hand and hit the center of the headliner behind the sunroof opening with the other. I've had several with that issue!
If this works, you almost certainly need to resolder the control box I mentioned earlier.
Posted: Sat Apr 25, 2015 7:51 am
by Binford
Alphius wrote:Binford wrote:Hold the close button with one hand and hit the center of the headliner behind the sunroof opening with the other. I've had several with that issue!
I don't disagree, but if someone has theirs stuck open, giving a little whack is easier than whipping out the little crank tool and climbing in the back seat!
Posted: Wed Apr 29, 2015 12:02 am
by dscoobydoo
Done the rear smack thing to the purple car. I need to re seal the sunroof so guess I am pulling it again this summer
Posted: Thu Aug 13, 2015 9:59 pm
by originalcyn
I'm going to piggy back on yours Drew, but on mine, the roof will open, and then not shut, but if i turn the car off and on again, often times i'll be able to shut it.
Posted: Fri Aug 14, 2015 3:09 pm
by Alphius
Reflow the solder on the thingy!
Posted: Fri Aug 14, 2015 6:48 pm
by dscoobydoo
I have not done it yet but both cars now exhibit this symptom. So time to get one into the garage.
Posted: Mon Aug 17, 2015 4:34 am
by originalcyn
Alphius wrote:Reflow the solder on the thingy!
I'm trying to figure out how to get you to say it another time lol.
In any case, blerg, cause now i have to figure out how to pull down the headliner. Thanks a lot Alphius! This is all your fault some how.
Posted: Thu Aug 20, 2015 3:00 pm
by cj91legss
It's not too bad. Just be careful, The front half with the sunroof cutout likes to bend and crease easily on the sides. A second set of hands would be useful.
Posted: Sun Aug 23, 2015 9:09 am
by originalcyn
Thanks CJ, i'll give it a go when i get another sucker to help me out.
