test mode connector wiring.
Posted: Mon Apr 06, 2015 11:41 pm
hi everyone. I'm having a problem identifying where the wire from the test mode connector (green diagnostic connector) leads. i have a 91 used legacy ss ej22t. when i bought the car the brown wire leading from the ecu to the green connector was intact but shortly after the green connector the wire (now black with red stripe) is broken and i can't determine where it leads. if someone can give me some clues to the where it leads i can solder it up and be on my way. cheers
-Trevor
-Trevor
