1991 subaru legacy ss
Posted: Fri May 15, 2015 2:11 am
Located in boise idaho. Looking to get around $6500. Or trade for motorcycle.
162xxx on the odo
Engine/Exhaust:
EJ22T closed deck
TD-04 19T turbo
Custom intake
Hallman pro mbc
Mishimoto FMIC
Mishimoto radiatior
Turbo XS bov
Modifid 2004 STI downpipe
Megan Racing Motor Mount
Flowmaster catback 3"
Walbro 255lph fuel pump
VMS oil catch can
AC delete
Transmision:
2005 Subaru Forester xt 5 speed transmission with a Modena front torque biasing differential (Torsen style) and PPG straight cut gears 1-4 and stock 5th gear
PPG input shaft and OE syncros
Exedy oe clutch
Exedy lightweight flywheel
2005 Subaru Forster 4.44 lsd rear diff
Custom short throw shifter
Perrin shifter bushings
Megan Racing Transmission mounts
MOMO shift knob.
Suspension/ Wheels:
Prodride Springs
KYB struts
Whiteline 22mm front swaybar
Whiteline 22mm rear swaybar
Whiteline havey duey rear endlinks
Whiteline Aluminum Sway Bar Mounts
Whiteline front heavyduty endlinks
2004 STI rims 5x100 17x7.5
Brakes:
EBC dimple/slotted disks
EBC yellow stuff pads
steel brade lines
Interior/ Exterior:
DEFI boost and pyro gauges
Innovate wideband
2003 wrx front seats
2 Kicker 12" subs
Kicker 6x9's
Kicker door speaker
Kicker 300watt amp
2006 STI s204 front lip.
162xxx on the odo
Engine/Exhaust:
EJ22T closed deck
TD-04 19T turbo
Custom intake
Hallman pro mbc
Mishimoto FMIC
Mishimoto radiatior
Turbo XS bov
VMS oil catch can
AC delete
Transmision:
Exedy oe clutch
MOMO shift knob.
Suspension/ Wheels:
Prodride Springs
KYB struts
Brakes:
steel brade lines
Interior/ Exterior:
Innovate wideband
2 Kicker 12" subs
Kicker 6x9's
Kicker door speaker
Kicker 300watt amp
