VF11 reliability with increased boost....?...
Posted: Mon May 25, 2015 2:16 am
by susiemk
Hey I'm BXSS username is sorta dead now
I have a silly question regarding the reliability of the VF11 with boost levels over stock.
I dumped my vf11 after just getting it up to 10 psi & had no issues with it
But
I know folks have run more than 10 psi for extended periods of time, if you have run more than 10 psi please reply with your vf11boost level & amount of time you ran at this boost level.
Thanks!
Re: VF11 reliability with increased boost....?...
Posted: Mon May 25, 2015 11:27 pm
by MConte05
I run at 12psi in the rally car, this is 20+ mile long stages at full boost, turbo glowing red hot, the turbo probably sees more abuse in one rally then in a lifetime for most cars. Plus it has 175k on it.
I just pulled the turbo off to swap out exhaust manifolds, and intended on replacing it with another VF11 thinking for sure it has to be nearly dead by now. Nope. Zero shaft play, spins freely, in great shape.
The VF11 is a rock solid turbo.
Posted: Tue May 26, 2015 1:22 pm
Yeah, as long as you are running good oil and change it regularly you should be able to increase the boost a bit.
Posted: Wed May 27, 2015 2:44 am
by susiemk
Good to hear.
I've seen big turbos gt45 / s400 sized die soon after an overboost episode (takes a huge over boost to kill the s400s like 60-75psi), so its good to hear the tiny vf can take a little bit of extra boost with good reliability.
I have a Forester 4eat running a ej20g with a teeny tiny little vf11, hot air with a ss charge pipe on it...
Believe it or not the vf11 is about as laggy as a 16g on the 2.0l engine (my ss has a 16g, fmic, 3" tbe, ej20g) but I can stay out of boost very easily while cruising so this low cfm turbo fits my "ecoboost" need very nicely & gets 30mpg on hw/ rural road mixed driving.
It makes about 33% more power @ 5psi than a 4eat ej251 forester with el headers, LW crank pulley, k&n drop in filter we have in the family so its an improvement over the ej25 in my opinion.
Posted: Wed May 27, 2015 1:04 pm
by susiemk
Wondering if the 10% smaller 2.0l engine would allow the VF11 to push out 10% more boost over the 12PSI ej22 max boost with similar efficiency...?...
I'm currently testing boost limits of the EJ20G/VF11 hot air (looks like 8.5psi is the safe limit before detonation (had a hunch this was the limit from my SS experience)), once I'm done I plan on testing the boost limits w Methanol injection hoping to run 13psi safely with the meth - ? if it will be possible.
Does 13 Vf11 psi on a 2.0l sound about right?
Posted: Wed May 27, 2015 5:23 pm
by SILINC3R
Why not just run a top mount? Meth is fun but if you run out you're done.
Posted: Wed May 27, 2015 6:30 pm
by susiemk
I really wanted to keep the car 100% stock (grandma appearing) so I did not want to mount a scoop for the TMIC (have 2x06 WRx/FXT TMICs + a meth kit laying around).
My turbo friends look underhood & think the car is nA which I find funny but there is no intercooler & its a ugly old forester which did not come turbocharged
I Have a pretty big meth tank that would take a while to empty (2 tanks of gas before it was low on my OBS-t) & I check oil / meth levels every few days.
That said I measured underhood temps yesterday with a laser pyrometer & the IM was HOT, 160+*, 86* ambient temps AC running - so I may need a hood vent & if I have to make a vent I may as well slap a TMIC on the car/trucklet...
Posted: Sat May 30, 2015 11:01 pm
by susiemk
Got the meth kit on & cranked the boost up - got about 13psi, 14 psi on shifts (4eat) no knock injecting wwfluid -20*...
"Hi" boost power is up 62% over our ej251 el header/k&n/LW pulley 4eat sf forester.
I'm happy with this performance so I won't vf10 (much bigger than a vf11), td04,or td05 16g this deceiving little bread box.
In my experience 50/50 meth makes more power than ww fluild but I wanna keep everything simple / wife friendly which means no mixing methanol...
Trying to hook her on boost - my parents are in their mid-upper 50s & have 3 turbo Subaru's - boost is a must when they buy a new car
Posted: Tue Jun 02, 2015 1:09 pm
by susiemk
SILINC3R wrote:Why not just run a top mount? Meth is fun but if you run out you're done.
Thinking about an 06 WRX TMIC / GC8 Scoop on the bread box...
Naaa stock appearing is OK with me...
