Weird power loss at high speed...(troubleshooting)
Posted: Thu May 28, 2015 8:04 am
G'Day,
I have a strange problem with my '93 Liberty & I'm hoping someone might have some ideas about the cause...?
(I'll admit I haven't searched the forums much because the problem is so strange and specific I doubt there will a post with the same scenario / problem...)
The car is an AWD '93 Lib. wagon with the EJ22E & and a 4EAT auto.
It has about 185,000 on the clock and is our daily driver / family bus.
The engine is strong and the AWD system works well.
The car drives fine and accelerates smoothly under almost all circumstances and any speed....except the following....
There is a hill near our place heading out of town. It's quite steep and it's looong. Like over a kilometre long. The speed limit is 110 km/h and it's a real car killer. You start from the red light at the bottom and just as you're getting to about 100km/h with your foot down, the gradient really starts to kick-in. Half way up and the tranny is now back in third (and sometimes screaming in second) and the engine is pulling around 4000 rpm to maintain about 100 km/h. This is normal. Your right foot is pretty deep into the pedal. It's the same for any car, it's a long hill that sorts out the slugs from the rockets. For the drive-train it is a combination of high fuel demand, high load and high speed.
At around 2/3rd 's to 3/4 of the way up my engine starts to lose power quite quickly. At first it seems to slow a little so you push the pedal even further, but within about 100 meters the revs are falling quickly and the speed is dropping rapidly. The engine seems a little rough but there's no weird noises or vibrations.
All I can do is pull over (it will literally slow to a stall if you don't, I've pushed it to complete failure once) and restart the car. It then drives away normally.
The worst part is, it doesn't do it every time we go up that hill.
The problem cannot be replicated anywhere else or under any other circumstances....and we live on a steep hill that the car goes up & down every day without issue.
It doesn't throw an ECU or TCU fault code when it happens either.
I have replaced the fuel pump with a new unit but has not solved the problem (although it seemed to go up the hill a little better at first....)
My thoughts are:
1. Fuel pressure regulator is leaking vacuum and not pulling open enough at high fuel demand...??
2. Air Flow Meter signal breaking down...? (but why no fault code generated?)
3. Spark integrity breaking down at constant high load...? (I replaced the plugs, leads and coil about 10 - 15,000 kms ago...)
Sorry for the long post, but it's a very specific problem and I wanted to give as much info as I could.
Many thanks.
My thoughts are:
Many thanks.
