Ej22t non turbo build
Posted: Thu Jun 18, 2015 1:12 pm
by justin the subie
I'm interested in doing the ej22turbo motor due to forged internals and piston oil squirters but need it to be non turbo due to expenses and car configuration. And I already have the motor. Can i build it with n/a heads and have good compression?? Or is there another good way to build this type of setup??? Thanks guys :smt033
Re: Ej22t non turbo build
Posted: Thu Jun 18, 2015 1:50 pm
by mike-tracy
The crank is forged, like all other ej engines. The rest, is not. Also, the 22t pistons make for a low compression build, so those have to go.
Theres a bunch of threads on this topic. Here's one of the better ones: http://bbs.legacycentral.org/viewtopic.php?f=5&t=52936
Posted: Thu Jun 18, 2015 5:37 pm
Honestly, I don't think you're gaining anything by going with the ej22t engine. The turbo cams won't be the ideal setup for a non-turbo setup. If you don't want to go turbo, then just stick with the non-turbo ej22 engine.
Posted: Fri Jun 19, 2015 12:24 am
by robertpaige
What Josh said. ^^^
There really is no point. You might as well just do a 25D/22 hybrid 'frankenmotor'.
Posted: Sun Jun 21, 2015 4:06 am
by justin the subie
Ok. Thanks guys. The only bummer for me is only having turbo motors. Haha. Suppose this car might just have to be unnaturally aspirated. :smt033
